ductwork estimation ?
hi friends
what is the equation i must used to estimate ductwork and insulation by square feet method ?
any articles will be gratefull
thanks for all
thanks for all
RE: ductwork estimation ?
I'm sorry, but your question is much too vague / broad to be answered. Perhaps you could give a few more details, explaining exactly what it is you need help with?
Brian
http://www.connel.com/freeware/airduct.shtml
i need estimate duct system for a/c and the owner want from me estimate the cost per square feet so i need your help
to estimate the quantites for this dimenstion :
30 feet * 20 feet (dimension of duct )for 15 feet
best regards
to estimate the quantites for sheets and man . hours units required for this dimenstion :
best regards
thanks for all
my queation is very easy
i estimated the ductwork by weight but i get in one project
the owner want from me the cost per square feet .
how can i calculate it ????
best regards
W = Width of the duct
H = Height of the duct
L = Length of the duct
i.e. you multiply the perimeter of the duct by the length fo the duct to arrive at the area.
Please check whether you have stated the units correctly. i.e is it a 30 feet x 20 feet duct ???!!!
HVAC68
thank u very much for your valuable equation HVAC68.
now if i want to estimate the quantity of insulation what is equation i must used ?
if the duct is round in this case what is the equation i must used to estimate (the cost per square feet)?
thanks again for your equation
best regrds
For a circular duct, the perimeter would be 2?R, where R is the radius.
HVAC68
HVAC68
