European Manufacturers & CE Approval?
I'm working on a job to be installed outside the US. The HVAC equipment includes:
- 100% outside air truss-mounted hot water heating and ventilating unit (about 6,000 CFM) - filters, coil and fan;
- 100% outside air truss-mounted ventilating units (up to 6,000 CFM) - filter and fan;
- 50 MBH hot water horizontal unit heaters;
- 3/4-ton self-contained heat pump unit (thru-the-wall).
I'm trying to select equipment but the tricky part, aside from the unusual (to me) electrical characteristics, is that equipment must be CE approved. The US manufacturers I'm familiar with do not have this approval rating, let alone the 50 Hz electrics (400/3/50 and 230/1/50).
Can anyone point me to web sites, or provide contact information, for any European manufacturers of this equipment that carry CE approval - or of US manufacturers who can provide equipment with CE approval?
RE: European Manufacturers & CE Approval?
Select the equipment from the catalog appropriate to the country you are selecting for. Different countries have different codes/standards and the specifications may be rather dissimilar.
http://uk.carrier.com/
HVAC68
