Using 'getcoordinates'
5
Can anyone help me figure out how to use the technique 'getcoordinates' of a point from a different axis system???
Thanks in advance.
RE: Using 'getcoordinates'
read PInt - CAA IDL in help docs
Thanks for the information, but I was wondering if you can provide some clarification?? Which 'help docs' are you referring to? Is there a link to this information that you can provide?
the docs are found in the help menu. all you have to do is point to the html file the first time. I believe it's a saparate installation. roughly around 1.5GB. usually stored on the network in a company environment.
Thanks for the help. Now, within the help documentation I assume I need to be looking in the 'Automation Documenatation'. But, I can't seem to find information about PInt - CAA IDL within this. Any other ideas that I can try?
Go to c:\Program Files\Dassault Systemes\B14\intel_a\code\bin\V5Automation.chm and do a search of what you want
Fernando
Thanks to everyone for their valuable input, but, unfortunately I am not any closer to a solution. My problem is that I have some code in a macro that finds the coordinate information of some points but the X,Y,Z values are based from the default axis system:
Set originPts = hybridShapes1.Item(1)
    originPts.GetCoordinates originCoord
What I would like to find out how to do is the same X,Y,Z values for these points except relative to a different axis system.
It seems to me that your problem is not with the GetCoordinates object, but rather the originCoord variable.
Don't you just need to swap it out for the coordinate system that you're after? (set the new coordinate system = to newCoord, and replace the originCoord variable)
CAD design engineering services -  Catia V4, Catia V5, and CAD Translation.  Catia V5 resources - CATBlog.
Unfortunately, I have the same problem with however I have my varible named. I originaly had my code like this:
Dim pts
Dim Coord(3)
Set hybridShapes1 = hybridBody1.HybridShapes
nump = hybridShapes1.Count
For i = 1 to nump
Set pts = hybridShapes1.Item(1)
    pts.GetCoordinates Coord
'display result
next i
Extracting the coordinate values of the points I have in the hybrid body that this is searching gets the coordinates based on the default axis system.
I'm trying to write my code to act like the Measure tool does when the 'Other Axis' box is checked.
You'll find that it isn't possible to get the coordinates relative to another axis system using the VB API.
You need to get the point coordinates relative to the part axis system and then get the axis system origin and orientation vectors relative to the part axis system (assuming they are both in the same part).
Once you have this you need to perform the appropriate  matrix transformations to calculate the point position relative to the axis system.
If the points and the axis system are in different parts of the product it becomes much more complex.
I think that you also have an error in your code:
 Dim Coord(3)
should be:
 Dim Coord(2)
If you've just created the point in your script, make sure that the part has been updated before you call GetCoordinates.
Thanks for everyone's help. Looks like I'll go to plan "B" and do some calculating.
Have a look at catiav5forum.com  in the download area.
I've post a VBA code to get XYZ to text file.
Eric N.
AHay's idea seems to be a good one.
If I understand this correctly, one could create the relevant coordinate system, and write a macro that would do the following:
1) axis to axis translation of the numbered points, one at a time AS A COPY. (all steps are based on the i=1 to number approach, including step 1)
2) measure point in originCoord. (to which it was just translated - relative measures are identical)
3) return value to Excel
4) delete copied point
5) loop to next point, until end
