Drawing views not parallel (True) to screen.
I have a CatProduct model, which consists of several parts.  Most are catparts, but a few were step files brought into Catia.
The problem I am encountering is when I go to create the initial drawing view (Front View).  I then select a reference plane as is required.  The drawing view that appears, is not parallel (True) to the screen with regards to the surface I selected.
The drawing view is created as an Isometric view.
I thought that maybe it was a setting, but this file appears to be the only one that is experiencing this problem.
Any help resolving this problem would be great!
Thank you.
RE: Drawing views not parallel (True) to screen.
Stick a temporary, empty V5 part into your product.  Select one of the axis planes from that part for your view.
If you want it on another skewed plane, create a datum plane in the temp part from the surface in the step file.
