Sample quill in small diameter pipes
We are designing a sample connection to be installed in a 2" produced water line. this lines operate in a intermitent service.
Is it possible to install this sample connection without a sample quill?. Pipig group has problems with the installation of quill in small diameter lines. The other option is increase the size of the pipe in a short section in order to install the quill. However we thought that it is not necessary.
I would like to know your esperiences or recomendations regarding this simple question.
Regards, Hianbo
RE: Sample quill in small diameter pipes
You could install a sample probe on an elbow facing into the flow, as per some thermowell installation.
Hianbo
The purpose of a sample quill is simply to try and get as representative a sample as possible, i.e. from pipe centre where there is no sediment etc.
If your pipe diameter is small then a sample taken from somewhere other than dead bottom of the pipe will probably be just as good as one from centre line, especially of the velocity is turbulent (Re > 2000) in the line (well mixed)
Hope that helps
