Minimum Path Turning Templates
I'm designing a tightly spaced mini storage building site and would like to make sure that, at a minimum, a truck with a trailer could maneuver through the site.  Does anyone know where I could get any cad templates to help with my design.  I have the templates in the Green Book but thought I'd ask to see if there were existing ones before I set out to draft the ones I have.
Thanks for your help.
RE: Minimum Path Turning Templates
I don't know of any cad templates. I have a couple ideas.
There is an add-on to AutoCAD called AutoTurn.
Another idea is to scan your templates as an image, scale them to the correct size/scale and overlay into your CAD drawing. You may have to do a DRAWORDER and send the image behind your parking lot.
Unfortunately, though, my firm uses Microstation and our only scanner broke down this week.  I think I will take my book home and scan the pictures with my scanner and do as you suggested, in the morning to check myself.  Also, I ended up drafting out several of the design vehicles templates if anyone is interested
Thanks again
I think there is a MicroStation version of AutoTurn, too.
     "...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail."
              Wm. Phelps Eno, ca. 1928
cveg05, I can send you an autocad drawing that shows the methodology.
Dik
Thanks for everyone's help, I really appreciate it.  I'm actually suprised that this information isn't more readily available.  I thought that somewhere on the web an agency would have it available to download.
