laminate cores
laminate cores
i was speaking with a machinist today about magnetic cores. he showed me his magnetic transfer parallel blocks for his magnetic chucks. would there be an advantage to having cores made of a laminate material-(brass shim stock alterneting with steel shim stock)? im wondering about the advantages of less residual magnetics vs the generated attractive force. anybody know if somebody is making anything like this?
tim
tim
RE: laminate cores
It would be more helpful if you could describe more of your application. Most magnet designs are optimized for particular applications. The design of a magnetic chuck are optimized for that particular function.
RE: laminate cores
tim
