joint(support) in a plate
I am modelling a plate with a hole in this . I used open structure wizard to this . Now I need to specify two joints where my support will be located . This two joints are not same as the joints created by triangular plate elements . I inserted those two support joints on the joints and specify those two joint a pinned support . But while analysis the structure , it stops saying that those two joint are not connected and structure is dejointed . Please help me how I should specify these two supports in the plate . Thanks
RE: joint(support) in a plate
