BMX & Regenerating Twice
Hi all
I'm still plugging away at my model and I'm integrating some analysis features to set some values.
I have a variable section sweep which is controlled by a datum graph feature. A dimension in the graph feature is driven by a value output from an analysis feature which tells me the length ratio of a point on a curve.
In order to make my VSS update, I need to regenerate twice. It's not really a big deal since I usually regenerate a bazillion times, but I'm just worried someone might miss that in the future.
Is there a way to force Pro/E to update the parameters which my graph refers to while it is regenerating?
RE: BMX & Regenerating Twice
Did you try?
-Hora
I'll let you know if it works, thanks
