Looking for Encoder
Looking for Encoder
Looking for Encoder
Hi all!
Does anyone recognise this encoder and manufacturer?
AEBRIELTD (or perhaps AEBRIE Ltd??)
model 9DITCW/33/24-P/6 24Vdc Optical
My customer has one that has gone wrong and asked to find a replacement.
The best info would be the number of pulses as 24Vdc encoders are easy to source.
I look forward to any replies and thank you all in advance.
RE: Looking for Encoder
Usually you can get any encoder with many different
resolution (# of pulses/rev) - so unless the partnumber
includes the resolution info, you can't find it out.
What is the diameter and the required resolution?
If you don't know :
What is it used for? Do you have the data/schematics of the
circuit which uses the output?
Plesae read FAQ240-1032
WEB: <http://geocities.com/nbucska/>
It would be possible to find it out experimentally by
1.) installing a high but arbitrary resolution
encoder
2.) inserting a frequency translator circuit into the
output and set the frequency ratio experimentally
