Array to follow a path
I have a number of handrail posts that are on a pathway. I have made the lines and arcs making up the side of the pathway into PL and joined into 1. Is it possible to array the posts along this line with set centres. With rec and polar in the array box not being any use is there another way. I am using Autocad 2006.
Thanks for any help
Thanks for any help
RE: Array to follow a path
try "_measure" or "_divide"...
Lothar
ADT 2004
ACAD 2002
make a block with Your posts with the right inserationpoint. "_divide" -> block -> your blockname -> array yes/no -> segments...
Is that, what are you looking for...?
Lothar
ADT 2004
ACAD 2002
Thanks a lot.
