ODB file in initial condition in CAE
hi frds
I am working in ABAQUS CAE and i want to use an odb file as an initial condition and i have specified the file in
Step--> initial--> Field
and created a field and included the file by selecting in Field editor dialog box-->distribution--> From results or output dbfile--> and select the file from the location
and when i submitting the job it says
¨The following path is not located: C:/......... (by specifyin the path of my odb file)
plz tell me a solution wat to do
i want to do in CAE not in inputfile
thx
thx
RE: ODB file in initial condition in CAE
corus
i rectified the problem
it was some mismatch of path location as u said
for example
i browse and select from my path C:/Documents and settings
the unix system doesnt accept the space between documents
¨-¨and¨-¨settings
that was the problem
and we shud have the part file .prt with the odbfile in the same folder
thx again
sheriff
