SSR for motor control
Hi. I would like to know what the outcome would be if I supply this SSR ( www.power-io.com/products/hdd.htm ) with voltages within it's range but more than twice (40 kHz) the cycles it's tested at.
RE: SSR for motor control
Why not contact the manufacturer and ask them what would happen if you were to supply an overfrequency to their SSR.
You may induce a state where the device is modulating instead of switching. The losses incured by the modulating service will probably induce rapid failure from overheating.
yours
Eng-Tips: Help for your job, not for your homework Read FAQ731-376
respectfully
Something like:
http://dkc3.digikey.com/PDF/T062/0848.pdf
Keith Cress
