Rated vs. Actual Capacities for determining pressure drops
Hello all,
I have a question concerning the calculation of relief valve discharge pressure drops. I've tried searching past threads, but I haven't seen any that discuss this particular question. If I've missed it, my apologies.
My question pertains to a conventional spring loaded RV in vapor service protecting a vessel with an allowed accumulation of 10%. The RV SP = MAWP. Therefore, at the relieving pressure, the rated and actual capacities will be equal. However, if the case would be for fire, then the allowed accumulation would be 21%. When determining the discharge pressure drop from a relief valve, should you use the relief valve's rated capacity (adjusted for actual fluid) at 10% overpressure or the actual capacity at 21% overpressure? I am aware of the API allowance of exceeding the 10% rule for these cases, but shouldn't the discharge pressure drop be based on the rated capacity since at this flow you run the risk of chattering and/or closing? Is one way or the other incorrect? I hope I have given enough info for this problem. If I have been unclear, please let me know. Thanks.
RE: Rated vs. Actual Capacities for determining pressure drops
Good luck,
Latexman
