Residential Steel Design
I am designing a residential steel and composite concrete slab structure? Does anyone have any information on what an acceptable initial deflection for steel beams would be? I know that in commercial applications, it you does not matter due to a higher tolerance allowed by finishings i.e suspended ceilings. A house however could be unforgiving with a much more strict allowable deflection criteria. I was trying to keep the initial deflection to 0.75 in. I know that the the floor will be poured flat, but I wanted to know if anyone just had a reference on construction deflections. Thanks.
RE: Residential Steel Design
