Cryogenic Steam Tables
Does anyone know where I could get a copy of cryogenic steam tables?  Mainly needed for O2, N2, and Ar.  Other gases would be helpful too.
thanks!
RE: Cryogenic Steam Tables
mminford:
There is no such thing as a cryogenic steam table.  Steam is simply not a cryogen.  However, I suspect you mean you are seeking thermodynamic values for liquefied gases in the cryogenic zone (< -150 oF).
If I've correctly guessed your interest, then go to:
http://webbook.nist.gov/chemistry/fluid/
and you will find the thermo data you are seeking not only for Oxygen, Nitrogen, & Argon but for approximately 30+ other elements and compounds.
I hope this resolves your need and that it helps you out.
I was looking for something more in tabular form.  Do you know any books or sites I can find that?
mminford:
Your request still doesn't make sense.  The NIST website gives you an explicit, downloadable tabulated result of any range or pressures/temperatures that you desire.
And what's more, it can be pasted directly into Excel.  What better tabular form is there?  Perhaps I don't understand your needs correctly, but I'm following your english-described needs as precisely as I am able to.
Thanks, I did not know you could create the table.
