Anti-sway bar spring constant
I'm in a back-and-forth with a guy on a car board about the stiffness of an anti-sway bar.  From what I recall (and from what I've found in my old texts), a solid bar in torsion has a spring constant that varies with the 4th power of the bar diameter.  The spring constant is given for a soild bar in torsion in my old (8th edition) Mark's Handbook as: k=G*Ip/L where Ip is the polar moment of inertia which is defined as pi*d^4/32 where d = diamter of the solid bar.
Hence my assumption that the stiffness of a sway bar was proportional to the 4th power of the diameter.  Is this correct?  Here's the link to the thread in question: http://www.bimmerfest.com/forums/showthread.php?t=145483&page=2  (post #32 and lower).
Chuck
RE: Anti-sway bar spring constant
The units for moments of inertia are [length]^4, so appropriate functions of Do^4, (Do^4 - Di^4), and, as an approximation for a thin-wall tube, Dmean^3*twall, are dimensionally correct.
[length]^3 terms such as Do^3 or (Do^4 - Di^4)/Do are involved in section modulus quantities, which are related to component stress under load, not stiffness.
Norm
Thanks Norm.  It's been 25+ years since I studied this in undergrad school, and I specilized in heat transfer and fluids in grad school, but I've been out of the engineering world now for more than 15 years. :(
Your response has pointed me down the right path to reviewing/understanding this subject once again.
Cheers,
Chuck
