Slenderness of columns
I tried to find (I am not good at it) CosmosXrpress forum but could not.
- Could anybody give me link to cosmosexpress forum ?
- More important - I need a quick answer: Does the CosmosXpress considers slenderness of columns ---> buckling when columns are subject to compression load ? I guess it does but I would like to hear it from some gurus.
Thaks in advance.
RE: Slenderness of columns
I don't think there is a forum for COSMOSXpress.  There is one titled "SolidWorks: COSMOS" <http://www.eng-tips.com/threadminder.cfm?pid=1183>
COSMOSXpress is very limited.  Probably does not have buckling.  I haven't seen it.
I remodeled the column to have it with a very thin wall - 1/8" instead of previous 1/2" hoping that this time it would almost certainly buckle up.
The program did NOT finished (I tried it twice) - this time I am getting message: Not enough boudary conditions.
My guess it - it means the vertical column simply collapsed ?
I doubt COSMOS Express would be failing because of the memeber failing under buckling.
I would be very very wary of using Cosmos express in this way.
There are some very simple calculations available for buckling by (amongst others) a chap named Euler.
In its simplest form for pinned ends
Pcritical=(pi^2EI)/(l^2)
Where Pcritical is the critical buckling load, E is modulus (207 GPa for steel) and I is the second moment of area of the column.
DW
COSMOSExpress doesn't do Buckling.  Why don't you just do the hand calculation.  They're not hard....grab a copy of Roake's Formulas for Stress & Strain - chapter 11 Columns
Euler's Formula P/A = Cpi^2E/(L/r)^2
Depending on your specific column geometry their are several conditional set ups.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
