Mechanical Properties of A588 Gr. A steel
I am sorry if this is the wrong forum for this but I am at my wits end.  Can someone here direct me to, or provide, the following mechanical properties for A588 grade A steel?
Elastic Modulus
Poisson's Ratio
Shear Modulus
Density
Tensile Strength
Yield Strength
Thermal Expansion Coefficient
Thermal conductivity
Specific Heat
all I know is tensile/ultimate strength is around 100ksi and yield is around 50ksi.  I can find any information anywhere on the other properties.  I have read that the properties change depending on the size and shape.  I am using plate less than 1" thick.  Any help on this subject would greatly be appreciated.
RE: Mechanical Properties of A588 Gr. A steel
The yield strength and tensile strength are specified in ASTM A 588, available from ASTM International at:
http://www.astm.org/cgi-bin/SoftCart.exe/STORE/filtrexx40.cgi?U+mystore+hkml0958+-L+A588+/usr6/htdocs/astm.org/DATABASE.CART/REDLINE_PAGES/A588A588M.htm
MatWeb has all but the last three:
http://www.matweb.com/search/SpecificMaterial.asp?bassnum=MSA588A0
And for those, you could use the values for 1020 steel:
http://www.matweb.com/search/SpecificMaterial.asp?bassnum=M1020A
Cory
Thank you SO much.  Was this the proper forum to post this question?
Yes
Cory
