Power - Reactive Power
Hi All - Hope you can help.
I have 2 Transport Refrigeration Units.
Unit 1 measures as follows:
Kw: 6.59
Kva: 8.11
Kvar: 4.77
PF: 0.81
Unit 2 measures as follows:
Kw: 5.28
Kva: 8.05
Kvar: 6.09
PF: 0.66
I need to advise which unit will heat cables less, or more and why. The customer in question has no power factor correction.
Kw: 6.59
Kva: 8.11
Kvar: 4.77
PF: 0.81
Kw: 5.28
Kva: 8.05
Kvar: 6.09
PF: 0.66
RE: Power - Reactive Power
yours
If these units are different voltages then the lower voltage unit would draw more current which would heat the cables more.
Eng-Tips: Help for your job, not for your homework Read FAQ731-376
