Dual Dimension Appearance
I'm a newbie to SolidWorks and I have a question on how to set up the dual dimensioning in the drawing. Can you change how the dual dimension appears in SW2006?  From what I see, it puts the secondary dimension on the top in paranthesis.  Can these paranthesis be turned off? Can you you change the order of how these appear?
Jen
RE: Dual Dimension Appearance
Have you looked in SolidWorks help?
Also do a search for DUAL DIMENSION.
Flores
SW06 SP4.1
If you go through the Online tutorial alot of your quesitons are covered there as well as the in the help.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
