Step translation problem
I received a iges file from a tool source, and need to send it to another source for other work in a step format. The 1st source uses solidworks but was unable to export it out as a step file without bombing out. I have translated the iges file into a NX3 assembly using the external. It has the assembly file and all the componets. When i viewed it in NX3, it was all sheetbodies. When I used the NX external translator to translate it to step, and back to NX to verify the data, there was no geometry. It had the same files structure as the iges to NX, but the geometry was missing from the step to NX translation. Any suggestions? I really need to get this data out. Thanks in advance.
RE: Step translation problem
I'm sure it would be a tedious intermediate step, but it may work. Maybe try it on one or two parts.
PP
