MPC constraint forces
Hello to everybody,
I'm simulating a crack. I'm working with a model using VCCT technique. I've lied two surfaces with a TIE multipoint constraint. I apply a load (MODE I).
The question is:
How can I obtain the constraint force at nodes?
Thanks.
Josep Ma
RE: MPC constraint forces
Hi josep
u mean the results or the value of forces at each node ?
You can request NFORC, nodal forces due to element stresses, which are not output by default.
Btw, what's the advantage of using VCCT over J-Integral? (as far as I know the accuracy is not one of them.)
Hi everybody!
Thanks for the answers. I'll try to request NFORC.
I don't know what you mean with using de J-Integral instead of VCCT in the case I'm simulating?
in any case.
