Video showing how to create a plane on a cylindrical face
I created this a while a go and wanted to share that.
let me know what guys you think.
http://multiterra.mooload.com/file.php?file=files/170506/1147878505/plane+creation+at+20+deg.swf
RE: Video showing how to create a plane on a cylindrical face
I can't get it to download. Is taking too long.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
try right clicking on the area where it says "Your download is ready.." and Save target as. the site says they block download accelerators.
regards,
Mark
Firstly let me commend you for creating the flash file and for sharing it with us.
A couple of points though;
1) You could have eliminated the need for creating the angled plane through the centre of the ring and then offsetting the second plane. If you had made the outer end of the angled construction line coincident with the perimeter of the ring, you could have placed a plane tangential to the perimeter at the correct angle by selecting the outer end instead of the inner end. This would then make the plane associative to the diameter rather than  the planes' offset dimension.
2) You can place the locating "point" for a Hole Wizard hole directly onto the outer diameter. There is no need to create extra planes. See FAQ559-1150. Again the angled construction line could have been used to constrain the point. An alternative to the construction line could be to use a plane which has been angled about the axis of the part & the point constrained to the planes.
http://img150.imageshack.us/img150/5214/holeondiameter6fo.jpg
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
My pc will not play the file. Company has it blocked.
Chris
AutoCAD 06
CorBlimeyLimey,
You're absolutely right. I'm aware of what you've mentioned, especially point #2. It's just that I was so happy to find a reliable file hosting site, that I uploaded the first file I found on my HD.
I will be creating more videos and sharing them with the forum soon.
regards,
Mark
See FAQ559-1177 for more hosting sites.
Look forward to seeing more of the videos.
cheers
btcoutermash,
your video got me thinking of a different way of approaching this task. I've just finished recording this one. let me know what you think.
http://multiterra.mooload.com/file.php?file=files/180506/1147973633/hole_tangent_to_cylinder_at_10deg.zip
Do you mind revealing what software you are using for these vids?  Is it Camstudio?
http://www.camstudio.org/
Flores
SW06 SP4.1
I actually use a program called Captivate. it's very cool and easy to learn and use. It's not that expesive either.
visit
http://www.adobe.com/products/captivate/
m1mason
I liked that video. Looks like a good way of doing it! Never thought of that one...
m1mason,
I like them. Keep them coming. Kinda like SolidProfessor lite. Thanks.
Reaper.
