Material Selection for Blank Flange
Hi Everyone,
I am having to carry out some pressure proof tests on some ceramic sleeves. The sleeves will be clamped between a pair of flanges.
I have designed the flanges and now need to select a material. It needs to have a yield strength of 355MPa and be readily machinable - it has to have o-ring grooves machined in it. It is only going to be used once or twice so does not need any special surface protection.
I have a number of sizes to produce ranging up to 180mm diameter. The maximum pressure (cold water) will be 400bar.
What material should I select?
RE: Material Selection for Blank Flange
If you are only going to use it a couple of times why not go common, cheap and thick?
Mike
