DRAWING - Detail View hatch editing
I am trying to edit hatch in a detail view of a section view. There doesn't seem to be a way to control this other than editing the hatch in the parent section view. The detail is scaled so what is good for the section is too fine for the detail.
SW2004
TOP
www.engtran.com
www.niswug.org
RE: DRAWING - Detail View hatch editing
I think the only way in '04 is to edit the parent view.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
Your Detail Views are a smaller scale than your Section Views? If so, ten why make a Detail View?
To modify the area hatch/fill of a DETAIL VIEW of the SECTION VIEW, zoom in on the detailed view and un-check the "Material Crosshatch" check-box.  Now you can over-ride the scale factor of the hatch.
Flores
SW06 SP4.1
Actually you have to check a box on the parent view to the detail in 2004. This box automagically scales the detail to maintain the same relative hatch as the parent. This came from a tip on comp.cad.solidworks.
In 2004 there is not individual hatch control on a detail view.
www.engtran.com
www.niswug.org
