hot tap impact temperature
Hello all
we are constructing a 48" crude oil line in accordance with ASME B313. we'll take a branch from existing line by a hot tap operation.
How can I find an information about at what temperatures does the impact have to be carried.
thank you all.
RE: hot tap impact temperature
By ascertaining the minimum design temperature of the piping (if it is a pipeline you would be using B31.4) and consulting B31.3.
Steve Jones
http://www.pdo.co.om/pdo/
