SA 182-F53 UNS S32750
What is the yield strength value for superduplex SA 182-F53 UNS S32750 ?
I can't find it in ASME II D
thanks.
thanks.
RE: SA 182-F53 UNS S32750
I need yield strength at 120 ad 60°C
If you go back and look at the balot that placed this alloy into the Code you will find the actuall strengths that it was based on.
Though in general I would presume that the strength up to 100C is the same as at RT.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
I usually upgrade the database putting the value of maximum allowable stress. I find these values in stress tables (ASME II part D).
This material is not endorsed for use in pressure retaining applications for boilers and pressure vessels. If you need material property data for this alloy, I would suggest you contact the web site below.
http://www.industeel.info/datasheets/main.asp
