Bubblerr Type Humidifer
I'm designing a benchtop bubbler type humidifier to saturate air with water. I'm looking for an appropriate vessel for this humidifier. I'm looking for something 1-2 feet tall and 4-8" diameter. Preferably with a removable top with ports for inlet (pipe with sparger tip), thermocouple, and outlet (humidified exhaust). Made of stainless steel, or aluminum, so I can wrap it with a heating pad and insulation to provide required heat.
I can't seem to find a vessel that is remotely like this description. I was hoping someone might be point me to someone who supplies these types of vessels.
Ryan.
Ryan.
RE: Bubblerr Type Humidifer
We usually make small stuff like this ourselves. You can also go to a fab shop and ask them to make one for you.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
StoneCold
Knew I should have mentioned that part!!!
Albert Einstein
Practically: That will be a lot easier to clean than a big chunk of pipe.
