hole in a nozzle
hole in a nozzle
is anyone answer if i drill a 2" hole in 12" nozzle attach on a cylindrical shell( orientation of nozzle is horizontal) what factors I have to consider? hole purpose to install purge out a gas without hot tapping? any body have a good solution
Syed
Syed
RE: hole in a nozzle
Once you have read through this code/standard, as well as an any applicable local regulations for your locale, feel free to come back and ask your question.
I don't know you want to drill this hole in live container or not.
If you want to attach 2" nozzle to 12" container you should refer to code but if you want to drill 2" hole in 12" live container that has another story!
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
