forcing diameter instead of radius.
ok, i've tried for a while to set radius to diameter in solidworks but have so far failed. the shop at my work wants me to give them their plans with diameters instead of radii, but solidworks refused to allow me to do so. does anyone know a solution to this?
RE: forcing diameter instead of radius.
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
The shop should use both.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
