HHO Weld Technology
HHO Weld Technology
HHO Weld Technology
I happended across an e-mail from my
Sister in California that was addressing
HHO Weld Technology.  Sounds too good to
be true.  Any one using it?
Is it a hoax?
RE: HHO Weld Technology
These have been around for quite a while.  You use electricity to separate water into Hydrogen and Oxygen.
You then burn the Hydrogen using the Oxygen and you have  a Hydrogen torch.
You get out of it the energy you put in as eletricity less processing loss.
You get water as a waste product.
You need to be careful what you use it on as you can also generate hydrides, oxides, etc.
Tom
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
