Creating a Smart Component with a Feature
I have been able to create smart components with assemblies, but I would like to associate a feature with a component such as a fastener that includes a hole feature that will cut into any part it's mated to.  Is that possible?  If so, anyone have any suggestions?  I am able to create this smart component with the hole feature, but I can only mate it to the same part to create the hole.  I would like to be able to mate the smart component to several parts and get the same results.
RE: Creating a Smart Component with a Feature
Have you tried using "Mate references"?
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I don't think I explained my situation very well.  (Or I don't get the mate reference tool.)  It is my understanding that the mate reference tool is just creates 'smart mates' not necessarily an added feature such as a hole.
I'll try explaing my situation again:
My base part does not have a hole for the 'fastener' to fit into.  Once I mate that 'fastener' to my base part, I would like it to create a hole in the base part automatically.  So far I can only get this to work if the 'fastener' is a smart component and the base part is ALWAYS the same part.  Unfortunately my base part will not always be the same, hence the need for a smart component.
Does that make any sense?
SW06 has Smart Components which does what you want.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
That is what I am working with.  I've been trying to define my Smart Component, but my problem is that evertime I add the Smart Component to a part it says it can not create the feature.  I think I might be setting up my Smart Component feature wrong.  Here's how I'm doing it:
-I insert a base part into an assembly.
-Insert the 'fastener' I want as the smart component.
-I create a feature (a hole) in the base part
-In the Smart Component window I have three windows:
  Smart Component = 'fastener'
  Component = none selected
  Features = hole feature
Is this the way you would do it?
I just tested this out and you can add more mate references to the part and those can be used when you bring the Smart component into the assembly. When you make the smart component it asks you to use features... I used the hole I mate the SC into. Then I broke the relationship when it prompted me too. Now i was able to insert the SC into a new assembly get it to mate to a prexisting hole or a face (added this as my secondary mate reference) and then I out the hole (feature) that I added when I was asked to put a feature into the smart component.
I hope this helps
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
It FINALLY worked!  Apparently you need to have mate references when adding a smart feature.
Thanks for the help!
