Cu Corrosion ASTM D130
G'Day All,
I am after information on the Cu Corrosion test ASTM D130 with regard to trying to corelate some fuel standards. There seems to be precious little on the net that actually describes the test (in detail) and interpretation of the results. I will be able to get a hold of copy of the standard in the near future but don't have the facilities at this time.
Am I right or wrong in guessing that #3 is worse than #1?
Cheers,
Trucky.
