Is "heavy gauge" defined?
Is there a definition for "heavy gauge" sheet steel?  In other words, does a sheet need to be greater than some minimum thickness to be called heavy gauge?  Or, as I now suspect, is this more of a subjective term?
RE: Is "heavy gauge" defined?
I'm pretty sure it's subjective based on the application.
The AISI "Steel Products Manuals" (which may be out of print by now) may shed some light on this. I will look around and see if we have those here. But, I vaguely recall that anything over 12 gauge was considered "heavy" and anything over 1/4" was considered plate.
I did locate the AISI books and there is a designation "Heavy Thickness" for coiled hot rolled sheet that applies to thicknesses over .180", which would be 7 gauge.
I've always taken "heavy gage" in a catalog listing or similar usage to just mean thicker than usual or plenty thick.  A "heavy gauge" beer can wouldn't have to be very thick.
