Turning Radius for tractor trailers
Want to help war effort?
I need to Know the turning radius for a tractor trailer (53') both inside and out.. ASap
Thanks Msgt. Spickelmier
RE: Turning Radius for tractor trailers
"...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail."
Wm. Phelps Eno, ca. 1928
When I was working in highway design a little over ten years ago, we used 50' for the truck turning radius. I do not know if this corresponds to a 53' Track-Trail but I guess you can start with that. This is the insdie radius, so you will need more room on the outside. I don't have the figures on 180 deg turns.
CPT(Ret) VAARNG - USACE - Ooo-rah!
See slide 13.
