Board cut outs for a new pattern
I am trying to create a new component pattern that requires the PCB to have several areas removed, cut out, to allow it to be mounted. They are polygons. How do I create the 'cutout' polygon on the correct layer? I have created a new layer and tryed to place it on the board but it doesn't seem to be working. The pattern is there but it doesn't work when the gerbers are created and I try to make the board on our LPKF mill. What's the trick?
