Safety Relief Valves
1. Can we classify Blowdown Valves and Shutdown Valves as safety relief valves?
RE: Safety Relief Valves
If you mean as in ASME safety relief valves, no.
In a HIPPS, there are "blowdown" and "shutdown" type valves, but they are to a reliability, maintenance, instrumentation and everything else in a HIPPS, much higher requirement.
So, in general, the answer would be that blowdown and shutdown valves are not safety relief valves.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
