Solid model of Small Block Chevy?
Does anyone know of a place to download a Solid Model of the Small Block Chevy, Ford, Dodge, Etc? Only need the outside Dimensional stuff internals mean nothing.
SolidDesign
SolidDesign
RE: Solid model of Small Block Chevy?
One of the better ones is here
www.carnut.com/specs/_engdim.html - 13k -
but maybe this is not the "solid model" you requested?
got
www.fordpowerproducts.com/FordPowerProducts/ pdf/C6TransSpecSheetrev10-04.pdf -
lots of "detail" in it.
I have a C6 here and will try to make a Solidworks model of it. It won't be easy with a tape measure. If it works out I will post it somewhere for everyone to use.
If you know someone who is a SEMA member and does transmission work, they can request a digital drawing of the transmission. I know this works for my stuff (Cylinder Heads).
Larry
Larry Coyle
Cylinder Head Engineering, LLC
www.cylinderheadengineering.com
