Saving Files
Saving Files
Saving Files
I am using SW2006 and a design company I deal with is using SW2005.They are having a problem with my native and STL files I send them.Should both SW's not be fully compatible.
RE: Saving Files
No ... Most solid modellers cannot (or do not) have the ability to be backwards compatible.
Questions about saveing down in Solidworks thread559-122558
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: Saving Files
DamianC,
      Just an idea. Would it not be easier to change your SolidWorks back to SolidWorks 2005 on your next project for them?
Bradley
RE: Saving Files
You shouldn't be having a problem with the STL files.  Try saving them as ASCII instead of Binary.  If they have SW, then try using Parasolid or STEP.
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Saving Files
If you still have the SW2005 disks, just do a separate install for their project. You might have to do a complete uninstall, then reinstall SW2005, then SW2006.
All in all, a good reason to keep your last version and create a new install of the next instead of doing upgrades all the time.
Are there any problems doing this?
Hardie "Crashj" Johnson
SW 2005 SP 4.0 (reluctant to change)
Matrox Millenium G550
AMD Athalon 1.8 GHz 512 Meg RAM
