conditioning of enclosed stadiums
hi guys
i ve been asked to design an air conditioning system of enclosed staduim its roof is an inclined I beam i its height gradually from its  top 5 mt till it reaches 17mt at the bottom. i will use jet diffuser at high height but at the low height what should i do ?
                            thanks
RE: conditioning of enclosed stadiums
Consider air conditioning only the occupied space.  Rather than using a jet diffuser at high level, supply all the air at lower level as in displacement ventilation systems, return at high level.  Avoid mixing into the high space.
If you are set with a mixed air system, try looking at Swirl diffusers for 5+m high ceilings.  These whirl (subtly) the air stream, and can be adjusted to sweep the airflow more downward compared to a typical diffuser which tries to coanda the air horizontally.  You can be assured of supplying the lower occupant zone.
hi CinciMace what is the displacement ventilation systems?? is the playing area should be conditioned?
thanx again
Be careful if the indoor stadium is for games like shuttle badminton.  The draft from the air-conditioning grilles/diffusers can play havoc with the flight and movement of the shuttle.
HVAC68
guys i need ideas how can i make load cal. for the playing area ?
i want to use inclined duct parallel to the inclination of the seat and use air nozzles directed to spectators  ill use return grills at the low level of the staduim?
any one knows or saw any sample of indoor conditioned staduim please tell me any site etc...
       thanx
You're going to have to do some search of ASHRAE volumes...this is not a simple question and it has no simple answer.
