ventilation og garage?
hi friends:
how can design ventilation system for garage ?
any suggestion ,articles will be gratefull
best regards.
RE: ventilation og garage?
If you are installing a system for automobile exhaust, fan and duct material are important and not standard.
General building and garage ventilation are very different animals.
If this is a parking garage, natural ventilation might be a good option either alone or in combination with a mech ventilation system.  This is usually well defined (regulated!) in standards and guidelines.  Check your local codes.
Check out this link from Vulcain.
http://www.vulcaininc.com/(sea5oe45oj2bqs45mmvonf55)/uploadedFiles/datasheets/Parking_Structures_Guidelines_EN.pdf
It should indicate also the use of gas sensors for control of ventilation systems. CO and NOx depending on the application.
hi friends:
thank u very much for every one help me
best regards
