Acad 2006 - Select objects within boundary
Is is possbile to select all objects found within a polyline (or boundary), regardless of z value (i.e as seen in 2d).
I've looked all over help but cant seem to find anything. Maybe a LSP routine?
RE: Acad 2006 - Select objects within boundary
Luckily we have map which I cant use but found out using boundary trim you can delete all those objects I was talking about (even though the description suggests it will trim rather than delete).
