external moment effects on bearing life
Hi;
i have a problem about the life time calculation of a bearing in a system. the system includes a shaft and a spiral bevel gear, a double row angular contact ball bearing and a clutch on this shaft. DRACB bearing carry radial, axial, tangential loads and moments. how can i calculate the life time of this bearing? meaning that how can i add the moment effects to life time calculations?
Thanks...
Baris
RE: external moment effects on bearing life
I give it about ten minutes, if you've only got one DRACBB.  You need to add a radial bearing to help with the moment loads, or use two separate ACBBs, spaced apart axially some distance.
Mike Halloran
Pembroke Pines, FL, USA
