How to make extrusion wich will start as circle and end as square
Basically what I’m trying to do is to make pipeline reduction that will start as round pipe and and as square which is 30x40 cm. what I wanted to do is to make solid that has the same shape as inner volume of reduction and then to make shell.
And problem is how to make such solid.
Do you have any tips and tricks for me?
Thank you
Miran
Thank you
Miran
RE: How to make extrusion wich will start as circle and end as square
Thank you all.
just beware (or be aware) that the flat pattern created after a lofted-bends operation is not 100% accurate due to the forming that occurs.
-Shaggy
RUFS
Kevin Carpenter
CAD Systems Specialist
Invacare Corp.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
