Reinforcement on a skewed bridge
hi,
i've post a question in an another forum :
http://www.eng-tips.com/viewthread.cfm?qid=154167
but will i have more chance to get a response here !?
RE: Reinforcement on a skewed bridge
At least in that method the reinforcing remains the same and the steel can be ordered full length and cut to fit in the fab shop.
THere are other ways of handling this but this is most common.
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
http://ww
www.SlideRuleEra.net
? = angle in between principal moments (M1) and direction of reinforcement
? = angle in between directions of reinforcement ? and ?
Mu = M1 sin^2(?- ?) + M2 cos^2(?- ?)
M? = M1 sin^2 (?) + M2 cos^2(?)
M’’ = M1 sin ? sin(?- ?) - M2 cos ? cos(?- ?)
Substitute moments (to size the reinforcement)
Mu ‘= 1/ sin^2(?) (Mu +k? M’’?)
M? ‘= 1/ sin^2(?) (M? +1/k? M’’?)
When ? =90°
then
Mu = M1 cos^2(?) + M2 sin^2(?)
M? = M1 sin^2(?) + M2 cos^2(?)
M’’ = (M1 - M2) sin?cos?
Mu ‘= Mu +k? M’’?
M? ‘= M? +1/k? M’’?
The factor k should be approximately 1.
You can get greek letters if you like. Click on the Process TGML link below the message window and it will show you the codes required to input greek letters.
Mu = M1 sin2(?- ?) + M2 cos2(?- ?)
M? = M1 sin2 ? + M2 cos2?
Mu ‘= 1/ sin2? (Mu +k? M’’?)
M? ‘= 1/ sin2? (M? +1/k? M’’?)
When ? =90°
then
Mu = M1 cos2 ? + M2 sin2 ?
M’’ = (M1 - M2) sin? cos?
Mu ‘= Mu +k? M’’?
M? ‘= M? +1/k? M’’?
The factor k should be approximately = 1
Looks better w/ TGML
