Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thank you. I have never said it, but you have a great web site. It is of immense help...."
Geography
riscphree (Computer)
12 May 06 7:02
I've got an older switch that has a serial connection to it, however, I do not have a serial cable for it.
I do however, have a serial to PS/2 convertor and tons of RJ-45 cable.
I just don't know what the pin out would be for putting the RJ-45 to my femle DB-9 convertor.
zappedagain (Electrical)
15 May 06 23:03
Google RS-232 pin out and you'll find lots of details.  Here is the first one I saw:
http://www.airborn.com.au/rs232.html
I know I've seen others but I don't have them handy right now.
You have eight wires in the RJ-45 so you'll have to drop one pin.  Losing pin #1 (shield GND) is only mildly risky; if you have a shielded RJ-45 you can run it on the outside.
I suggest monitoring your signals with a break-out box; you can probably get away without routing one of the handshake lines.  It all depends upon your application.
OTOH - There are lots of inexpensive RS-232 cables available on the web.  Is this project worth saving a few dollars?
robertjo24 (Industrial)
16 May 06 9:10
Typically, the RS-232 will only use 2 (RX Data), 3 (TX Data), and 5 (Sig GND). If RTS&CTS are required, pins 7&8 are shorted.
On the RJ-45 side, these will corrolate to pins 3,6,and 4 respectively. If you use a RJ-45 to DB9 adaptor, this will be the Black, Yellow, and Red wirs in the adaptor.
Close Box
Join Eng-Tips® Today!
Join Us             Close
