Modelling Pressure vessel in FLUENT
HI all
I want to know if there is any information on modelling a pressure air vessel.I want to able to know how long it will take for the pressure to decrease to the atmospheric pressure through an outlet.
thx
thx
RE: Modelling Pressure vessel in FLUENT
Well i looked into some fluid mechanics books and found thats most equations assume incompressible flow so , but do you have any information on how to do this uwing fluid mechanics basics
thx
This type of problem is typically dealt with in the examples in most fluid mechanics flow texts. The basic assumption is that the outlet flow area is much smaller than the tank cross section. Calculate the flow rate through the outlet area as a function of upstream pressures, construct differential equation of tank conditions (P, T) use known starting volume/pressure/temp. of vessel to provide an initial condition. Integrate, numerically or classically, to find time when tank pressure drops to ambient.
Volume of an ellipsoid = (4/3)(pi)abc
where a b and c are the lengths of the semiaxes.
