Temperature measurement differences of the skin
I am tasked with finding a low cost wearable portable method for collecting data on human skin temperature over time. It must be able to record changes to within
+/-.3 degrees. Any suggestions on where I might find this technology would be greatly appreciated.
jerry hahn
jhahnemail@yahoo.com
jerry hahn
RE: Temperature measurement differences of the skin
http://www.scigiene.com/cat46_1.htm
Did you mean +/- 3°C or +/- 0.3 °C?
What does low cost mean?
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
How many points do you need to measure?
You can buy commercial 'select' sensors with good accuracy.
There are very small data loggers (Hobo) that can record data.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Jerry Hahn
