Can a larger RPZ be installed on a smaller pipe?
This is probably moronic, but...I need to install an RPZ on a 2-inch water line, but the units that are approved, can be installed in the vertical position and will FIT w/o major repiping are all 3-inch or larger.
The pressure to this line is 90-100 psi and the demand is not high since it only serves a few eye baths and safety showers.
Thanks, jb
Thanks, jb
RE: Can a larger RPZ be installed on a smaller pipe?
Geoffrey D Stone FIMechE C.Eng;FIEust CP Eng
www.waterhammer.bigblog.com.au
